Cannot insert an Item into itself or its children
estringer
Message 1 of 15
estringer
I have created an IAM. file which is a release of units of parts. I then inserted other IAM. files containing the parts of the release. I was hoping to create an Item from this so that I could extract a BOM from the IAM. within the main IAM. but I am getting this error.
I looked into creating the Item by dragging and dropping the individual IAM. files into a new Item form but that would require a lot of searching for the individual IAM.s. Is there something that I can do so that a release IAM. type condition will work?
Replies (14)
Message 2 of 15
CGBenner
@estringer
It’s hard to tell just from these images, but it sounds like there is a circular dependency somewhere in your assembly structure.  For example, does one of the child subassemblies contain a reference to the parent assembly?
For troubleshooting, could you try to recreate this with a smaller assembly that you would not mind sharing in a pack and go?
Chris Benner
Message 3 of 15
Gabriel_Watson
Is the Lvl_16.ipt somehow a derived assembly still linked to Lvl_16.iam? Maybe that's why.
In Inventor you would get an error trying to include Lvl_16.ipt into Lvl_16.iam, but you may have attached it some other way in Vault:
https://autode.sk/3EErpj7
Message 4 of 15
estringer
The Lvl_16.ipt was created and then placed in to the Lvl_16.iam.
Message 5 of 15
CGBenner
@estringer
Can you describe how this was created?  That may explain this.
Chris Benner
Message 6 of 15
estringer
I created the Lvl_16.ipt and imported a DWG of a floor plan into the ipt. I then placed the ipt in the Lvl_16.iam and started using the Joint constraint to place unit assemblies on the floor plan.
Message 7 of 15
estringer
@CGBenner,
I have a smaller Assembly that I can do a Pack & Go on but it still exceeds the 71 MB max size. Is there another way to get the file to you?
Message 8 of 15
CGBenner
@estringer
Sending you a PM....
Chris Benner
Message 9 of 15
CGBenner
@estringer @Gabriel_Watson
D'oh!!  So simple,.... since the part and assembly are the same name, it is trying to create an Item for both.... with the same name.  hence the error.  All I did was to rename the part, and the Assign Item worked.  Thank you for sharing the files, try that and see if it helps.
Chris Benner
Message 10 of 15
estringer
@CGBenner,
That worked, thanks again for the help! It seems a little strange that you can't have the same name with different file types. I guess we will have to get a little more creative with our naming conventions!
Message 11 of 15
Gabriel_Watson
Hehe, I thought it would be too obvious so I wondered about references instead of the file name....
Message 12 of 15
CGBenner
Same, I was looking for a complex problem....
Chris Benner
Message 13 of 15
estringer
I guess my next question related to this then is how I get the Item to include all of the assemblies that are inside this main assembly? I was hoping to create a BOM of the assemblies and their related parts with the Item master.
Message 14 of 15
gbelloniGYTH4
I had this error occurring with an iam file (ABC.iam) made up of many subcomponents (ABC_01.ipt , ABC_02.ipt and so on). Even though the part numbers were different i still got this error when trying to assign an item to the iam file. I managed to solve it by setting the iam File as "Purchased" from within Inventor. If i do that it works fine.
Message 15 of 15
RajSchmidt
Normally an item’s BOM is created by reading the document structure of the IAM. So you simply can create/update the item for your IAM. On the BOM tab in the creation dialogue you should see that Vault tries to create items for all parts and sub-assemblies.
There is a number of settings to control this, see https://help.autodesk.com/view/VAULT/2025/ENU/?guid=GUID-FF26CEE9-A2B7-47BB-9FFF-1655D0A5C91B
