Can't get out of dialog boxes, Vault Basic 2025.2.1
XYZ965
Message 1 of 13
XYZ965
Hi all,
Commands like Attachments... Rename... Purge... left me stuck in their dialog boxes, so I couldn't get out of it, except to terminate the process with Task manager. This happens most of the time, or occasionally.
Not sure what's causing this issue.
Thanks!
Replies (12)
Message 2 of 13
gandhey
Hello @XYZ965 ,
Please try this to see if that helps :
https://help.autodesk.com/view/VAULT/2025/ENU/?guid=TBS-DIALOGS-NOT-ON-CURRENT-SCREEN
Yogeshwar
(Vault team)
Message 3 of 13
XYZ965
Please see the pictures below. Do I understand correctly what I should try?
Message 4 of 13
XYZ965
Maybe it is because I'm using Vault basic, and not VaultPro?
Message 5 of 13
XYZ965
Finally, I found a way to do what is suggested in the Help:
But unfortunately, it has not solved my problem.
For example, when I choose the Attachment command to detach an attachment from my .ipt file, after that I can't get out of the dialog box, except to terminate the process with Task manager.
Regards.
Message 6 of 13
gandhey
Hello @XYZ965 ,
Reset dialog location and client profile - would work for Vault basic too as you have tried above.
I tried the attach-detach workflow you said but I don't see issue. So if this above workaround is not helping - I suggest please raise a case.
Yogeshwar
(Vault team)
Message 7 of 13
XYZ965
Thanks for your support.
Would you please check inserted video?
Message 8 of 13
XYZ965
Hi @gandhey
Please can you tell me if this is normal behavior for Vault: when I just select a file that has an attachment, the CPU usage gets high, and power usage is very high.
In contrast, when the selected file doesn't have an attachment, the CPU usage is low, and power usage is also low.
Regards.
Message 9 of 13
gandhey
Hello @XYZ965 ,
No I do not see the power issue you are seeing.
Does this happen with all files that have attachment OR only specific file ? what type of attachment (extension/size) is attached to this file ?
Also does the power usage remain high on selection of this file? (or if you wait for few seconds or such it comes down?)
Yogeshwar
(Vault team)
Message 10 of 13
XYZ965
Hi @gandhey,
It happens with all files that have an attachment.
Types of attachments are .jpg or .doc, with a size of approximately 200 - 500 KB. The location of attachments is either in the library or with other engineering files.
Power usage remains high on selection, as long as it is selected. So I don't know if it is unusual?
Regards.
Message 11 of 13
gandhey
Hi @XYZ965 ,
That is unusual, I cannot see that issue as I test.
Machine reboot donot help either ?
regards,
Yogeshwar
(Vault team)
Message 12 of 13
XYZ965
Hi @gandhey,
Thank you for answering.
No, rebooting does not help either. I've been dealing with this problem for several weeks, and I've also raised a case, as you suggested. I'll post in this thread how it ends.
Regards.
Message 13 of 13
XYZ965
The problem was solved by Autodesk support. It was enough to uninstall - reinstall Vault client and now everything works fine.
Thank you, customer support Tim of Autodesk.
Best regards.
