Can't connect to remote SQL
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I tried to install the ADMS Professional 2015 on a new server and need to connect to a remote SQL server and i receive the known error : Failed to connect to SQL server- server=server\AUTODESKVAULT;user id=sa;password=******;
I tried a lot of things with the help of my DBA and we can't find the solution for this one.
Remote connection is enable on the SQL.
The user running the sql have access to the new server and the remote Share configured on the server where i install adms 2015.
We can log as SA and the default password on the remote SQL.
All firewall has been configured with the correct exceptions, even disable completly on both servers.
TCP/IP is enable and a custom port has been assign in SQL configuration manager. Alias configured in Cliconfig.exe (32 and 64 bit) for the new port.
Tried to redownload adms 2015.
Tried this, didn't worked.
I had this problem before and most of the time it's the SA password that is not correct.
Thanks for your help.
