Autoloader problems
Autoloader problems
johan.degreef
Advisor Advisor
Autoloader problems
johan.degreef
When trying to upload a perfect clean project, with no duplicate files, Auto loader did say there were duplicates.
When trying to disable the duplicate setting on the server, so that it would alow me to upload duplicates (I would solve this once uploaded), I got the error. (the scan went fine.)
What ways do you use to upload a project to a Vault?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
gandhey
hello,
Please check if following helps :
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Yogeshwar
(Vault team)
marina.collet
Do you have anyCAD links in your files?
Part files with AnyCAD links wil pass the scan step but will fail validation.
With assemblies, it depends on the Autolader version.
If you do have anyCAD links, you won't be able to load these files with Autoloader.
johan.degreef
Don't know AnyCAD, but there are some Autocad dwg's, included in sketches....
Still need to test @gandhey solution, but kinda busy right now. Will post back if it worked.
johan.degreef
@gandhey wrote:
hello,
Yogeshwar
(Vault team)
Deleting the BUU.xml file did not solve the problem. I gat this in a clean Vault with no files in.
marina.collet
Have a look at this thread:
https://forums.autodesk.com/t5/vault-forum/could-not-validate-files-using-autoloader/td-p/8618634
In the accepted answer there is an explanation on how to activate extended logging in Autoloader.
After doing so, run autoloader again and check the logs after the validation failure.
It should tell you which files rise this error.
