Hello colleagues, currently in my organization Vault is being managed but only for inventor use, but there was a need to do it with AutoCAD, I wanted to know if anyone knows what this process is like to do the integration with Vault, I don't know if it can be used the same vault with inventor and autocad, or does it touch two different ones, I would think that since they are different projects, any information can help me. Thank you
Hello @johannes_santos ,
Same Vault can be used for AutoCAD and Inventor. This is purely based on your project needs - if for one project you have data coming in from Inventor and also AutoCAD - you can use just one Vault.
Vault has component called Inventor Addin which is required for Inventor data management in Vault. Similarly there is AutoCAD addin which is needed to manage the AutoCAD data in Vault. Refer following for installation help:
How to install Vault Add-in 2022 for CAD 2022 applications (autodesk.com)
Hope this helps.
Yogeshwar
(Vault team)
Okay, thank you very much for the answer. I will try to do a test with what you told me.
Thank you very much, I will keep that in mind when I am doing this process.
