ASP error
ASP error
Dan_Margulius
Advisor Advisor
Message 1 of 15
ASP error
Dan_Margulius
I tried almost everything to solve this error. I am getting closer to reinstall W7 .
IIS is fine from what I can see.
What can be done?
Dan
Replies (14)
Message 2 of 15
yuhui.zhang
Try re-register the ASP.Net filters. At the command line, enter:
c:\windows\microsoft.net\framework\v4.0.30319\aspnet_regiis -i -enable
for x64:
c:\windows\microsoft.net\framework64\v4.0.30319\aspnet_regiis -i -enable
Fay Zhang
Software QA Engineer
Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 3 of 15
Dan_Margulius
Still not working.
Dan
Message 4 of 15
Hi Dan!
This error appears with me too.
Take a look.
1.    Open a command prompt.
 2.    Navigate to the %SYSTEMROOT%\Microsoft.Net\Framework\v2.0.50727 directory. 3.    Type“aspnet_regiis.exe –i” and press Enter.
4.    After this is complete, Type “aspnet_regiis.exe –GA ASPNET” and press Enter
 5.    Perform an IISRESET from a command prompt and restart the pre-checks
be sure that these commands are typing correctly, when you enter aspnet_regiis.exe –i
The same problem happened to me, and these steps solved.
Helder M.
Message 5 of 15
Andy.Spivey
Hi Dan,
The error listed is with the static file (text file).
Are you able to manually type in the path in the address bar?
If you open the IIS manager and view the default website, is there an entry for TestASP?  If so, select the content tab - is TestASPNetStatic.txt shown?
If TestASP folder or files are missing, please re-install by running x86\en-us\edmPrechecks\TestASPNet.msi
Andy Spivey
SQA Engineer
Message 6 of 15
Dan_Margulius
This what i have now :
Message 7 of 15
Dan_Margulius
I did as you indicated but this is what happened :Smiley Sad
Message 8 of 15
Andy.Spivey
Dan,
Please right click on the static txt file and select browse - from the second screen shot, you were attempting to connect to http://localhost80 instead of http://localhost:80
Andy Spivey
SQA Engineer
Message 9 of 15
Try these
2. Type the following command to enable the 32-bit mode: cscript %SYSTEMDRIVE%\inetpub\adminscripts\adsutil.vbs SET W3SVC/AppPools/Enable32bitAppOnWin64 1 3. Type the following command to install the version of ASP.NET 2.0 (32-bit) and to install the script maps at the IIS root and under: %SYSTEMROOT%\Microsoft.NET\Framework\v2.0.50727\as​pnet_regiis.exe -i
(if that fails try %SYSTEMROOT%\Microsoft.NET\Framework64\v2.0.50727\​aspnet_regiis.exe -i
4. %SYSTEMROOT%\Microsoft.NET\Framework\v2.0.50727\as​pnet_regiis.exe -GA ASPNET
(if that fails try %SYSTEMROOT%\Microsoft.NET\Framework64\v2.0.50727\​aspnet_regiis.exe -GA ASPNET
5. Make sure that the status of ASP.NET version 2.0.50727 (32-bit) is set to Allowed in the Web service extension list in Internet Information Services Manager.
Message 10 of 15
Dan_Margulius
if I click browse on the txt file nothing happens.
if i write with :80 also I get page not found.
Thank you all
Dan
Message 11 of 15
Andy.Spivey
Hi Dan,
Please ensure the correct IIS roles have been setup on the system - as indicated here:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0206-Autodesk206/0210-About_Yo210/0238-Installi238/...
Andy Spivey
SQA Engineer
Message 12 of 15
Dan_Margulius
You did it.
Thanks, i was just about to throw it all 🙂
Dan
Message 13 of 15
Andy.Spivey
Happy to help Dan - glad that did it  🙂
Andy Spivey
SQA Engineer
Message 14 of 15
This error appears with me too,but there is currently no text in this page, can u tell me how to resolve it again?
Message 15 of 15
Andy.Spivey
Hi - I believe the resolution was to ensure all the correct roles were installed inside of IIS.
The advanced configuration guide ( can be downloaded here) lists the required roles inside of iis.
If this isnt the issue you are having, please let me know more detail / a screen shot showng the behavior.
Andy Spivey
SQA Engineer
