I installed Vault 2013 on our server and on all of the client CPUs. I did not have a chance to install Inventor 2013 until a couple of days later. Now Vault 2013 and Inventor 2012 are seeing each other and running good, but Inventor 2013 does not see Vault 2013. I have tried uninstalling Inventor 2012 but that did not work. I have a threory though and I wanted to see if this is correct. When installing Vault 2013 on the server and I migrated the files into that vault it asked me what Inventor levels of inventor will be using the Vault. I would only allow me to check 2012. Is this why my Inventor and Vault 2013 will not see each other? And how do I get them to start seeing each other? Thanks
Solved by Senthil_Kumar. Go to Solution.
Can you try the following and let us know if that helps?
Go to Control Panel->Programs and Features->Select Vault 2013, RMB to Uninstall/Change->Add or Remove Features and see if Inventor 2013 is checked with green tick or not. If not go and select and complete the installation.
That should bring the Vault add-in inside Inventor 2013.
I Have the same problem, I tryed the recomendation but still doesn't work.
You have Vault installed and the add-in is inside. You just need to log in to use.
Refer the following help page for more information on how to log in and how to use Vault.
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-D8C6761A-33FC-469B-B801-8BD2EBB2A26E
