Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
ADMS - Number of days since the last server console backup - Not backed up
8 REPLIES 8
Message 1 of 9
john3NHRC
482 Views, 8 Replies
I ran a scheduled full backup 3 days ago and a full manual backup 4 days ago using backup and restore.
But ADMS console shows:
Number of days since the last server console Backup: Not Backed Up
The backups work as I have successfully upgraded from Vault 2019 to Vault 2024. I have done all updates and everything is working well and tested.  I ran a full manual backup once testing was complete. The scheduled backup which was completed Friday night completed successfully.
I look in event viewer and I see these errors:
Error Event ID 7105
The Database ID 7, Page (1:22194), slot 2 for LOB data type node does not exist. This is usually caused by transactions that can read uncommitted data on the data page. Run DBCC CHECKTABLE.
Are these two things related and how to do run DBCC CheckTable
Am I missing something?
Tags (2)
Labels (2)
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: john3NHRC
i also see this with Vault Pro 2024
even if i run a manual full back up & completes it still shows not backed up
this was a clean install of Vault 2024 it was not an upgrade install
restored a vault 2023 backup
DarrenP
Message 3 of 9
john3NHRC
in reply to: DarrenP
Maybe it is a Vault Po 2024 bug?
The Errors in Event Log worry me. There are many of them all identical.
Message 4 of 9
joseoltra
Can you share the Backup log?
Inventor
Revit
Vault Professional
Autocad
Message 5 of 9
john3NHRC
in reply to: joseoltra
This is the VaultFullBackup.bat file: "C:\Program Files ... ADMSConsole.exe" -Obackup -B"Y:\" -WA -S -L"Y:\log.txt"
Attached the log file.
I just did a backup from ADMS. Here is the logfile.
Message 6 of 9
ihayesjr
Thanks for reporting the issue. I am able to reproduce it.
I will have the development team take a look at it.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 7 of 9
john3NHRC
in reply to: ihayesjr
Thank you for looking into it!
Could this also be related to these errors found in the Event Viewer, Application Log?
Error Event ID 7105
Message 8 of 9
ihayesjr
Error Event ID 7105
No, that is an unrelated error.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Message 9 of 9
DarrenP
it seems this was fixed with the Vault 2024.1 update
the correct days now shows up correctly when a back up is complete
DarrenP
