Vault Forge viewer different versions
michael_marx
michael_marx
Why there are two different versions of Forge Viewer?
left one is from thick client and right one from thin client.forgeviewer.jpg
Is it possible to get them to the same version?
All updates are installed!
thanks
Michael
Gabriel_Watson
I tested on the Vault beta and both are showing the same version.
Perhaps your thin client is not updated on the server. Try clearing your browser's cache first to make sure it is not just that, and if that fails then you may need to repair the latest update:
https://resources.imaginit.com/support-blog/autodesk-vault-2023-thin-client-does-not-show-update-aft...
michael_marx
yes it was a browser cache problem. But not from the standard browser. It was the cfbrowser cache which is used inside the thick client.
thank you for the right hint. 😉
