VDF error : The requested security protocol is not supported.
Message 1 of 22
When trying to connect to Vault using the VDF API I get a "NotSupportedException: The requested security protocol is not supported."
I'm not sure how to proceed or what the error means. As far as I can see I don't need to configure any security protocol or do I?
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports Autodesk.DataManagement.Client.Framework.Vault.Services
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections
Imports ACW = Autodesk.Connectivity.WebServices
Public Class Form1
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("XX.XXX.XX.XX", "Vault", "UserName", "123456", VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing)
        Dim connection As VDF.Vault.Currency.Connections.Connection = results.Connection
        If Not results.Success Then
            MsgBox("Login error")
            Return
End Sub
End Class
PS: I'm very sad that there's no Python API for Vault. Just putting it out there.
PS2: there's a bug in the forum software that prevented me from posting. When posting using Firefox the forum returns an error "invalid HTML".  🙄  😫
Replies (21)
Message 2 of 22
bradeneuropeArthur
  • What version and release of Vault are you using?
  • Have you installed all Vault updates?
  • Are all references correct to the right versions?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 22
  • What version and release of Vault are you using? --> Autodesk Vault Professional 2019Build 24.3.24.0. 2019.3.2 Update
  • Have you installed all Vault updates? --> As far as I know: yes. See version number and update number.
  • Are all references correct to the right versions? --> Yes, the references are the dll files from C:\Program Files (x86)\Autodesk\Autodesk Vault 2019 SDK\bin\x64\    Solution platform in Visual studio is set to x64 CPU. Visual studio has no trouble finding the references correctly. The code compiles and runs just fine, it's just that I get back the aforementioned exception from the API on the first line of code containing --> VDF.Vault.Library.ConnectionManager.LogIn(
Message 4 of 22
bradeneuropeArthur
Please take a look in this folder:
This can have more updates from the SDK
then you need to deference these...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 22
The only relevant folder I see there is "Autodesk Vault 2019 SDK", this is the folder that contains the dll's in a x86 and an x64 folder. I'm already referencing the dll's from the x64 folder.
The only other folders in C:\Program Files (x86)\Autodesk are: "DM Apps" (sample projects) and "Autodesk Design Review".
Message 6 of 22
bradeneuropeArthur
Could you make a screenshot of the reference tab within Visual studio?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 22
Message 8 of 22
bradeneuropeArthur
The references seem to be OK.
What framework version are you on?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 22
The newest, freshly downloaded and installed yesterday.
.NET framework 4.8.03761
Message 10 of 22
bradeneuropeArthur
try 4.6!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 22
try 4.6!
I had the target framework set to .NET core 3.1 (which apparently somehow corresponds to .NET framework 4.8, totally confusing). I tried to set the target to .NET core 3.0. Same error.
Message 12 of 22
bradeneuropeArthur
is there any intellisence behind VDF.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 22
I'm pretty sure that the linking/loading of the Autodesk dependencies is going fine. The exception actually comes from the Autodesk lib; I wouldn't get that specific exception (from the DLL files) in case the DLL linking had somehow failed.
Message 14 of 22
bradeneuropeArthur
are you copying the libraries locally?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 22
No. They are linked to their original location in program files.
Message 16 of 22
bradeneuropeArthur
Could you try that?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 22
Same error...
It seems that the exception is triggered by the .NET runtime (and/or OS) using a different .NET https security protocol than the VDF API wants to use. I've tried setting SecurityProtocolType to TLS1, TLS2 and SSL3 manually which all also didn't work.
If only the broken VDF was open source... I'm giving up on this. This forum is broken in Firefox (--> Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.), VDF is broken with the newest OS and .NET versions. This just isn't worth it...
Message 18 of 22
I tried it. Same error...
Message 19 of 22
Tried it. Doesn't work. I also tried to post other insights, but my post keeps getting deleted after being marked as spam.
Message 20 of 22
bradeneuropeArthur
Can you upload the project maybe?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
