Hello Masters,
I have some problems with Vault Data Stand. When making components, Vault is generated the filenames with correct number scheme. Then saving the .iam => Datastand regenerate the filenames (For all documents). Btw, I must click OK for all documents (I don't want to fill anymore properties. I am using vault datastand because it helps to auto select categories and number scheme). See attached video to understand more!!!
How to custom that? What is the best workflow for working between Datastand and multibody files?
Thank everyone.
Hello Masters,
Thank everyone.
Solved by smilinger. Go to Solution.
This is my solution, we just skip all the data standard dialogs for multi-body parts:
in Default.ps1:
function InitializeWindow
#begin rules applying commonly
$dsWindow.Title = SetWindowTitle
InitializeCategory
InitializeNumSchm
InitializeBreadCrumb
InitializeFileNameValidation
#end rules applying commonly
$mWindowName = $dsWindow.Name
switch ($mWindowName)
'InventorWindow'
#rules applying for Inventor
if ($Prop['_CreateMode'].Value)
# the document is .iam and it is the active document
if ($Prop['_FileExt'].Value -eq '.IAM' -and $Document -eq $Application.ActiveDocument)
SkipMultiBodyParts $Document
'AutoCADWindow'
#rules applying for AutoCAD
$global:expandBreadCrumb = $true
# skip multi-body components
function SkipMultiBodyParts($doc)
$occs = $doc.ComponentDefinition.Occurrences
foreach ($occ in $occs)
if (IsNewMultiBodyPart $occ)
SetDocumentProperty $occ.Definition.Document 'User Defined Properties' 'SkipVDS' $true
function IsNewMultiBodyPart($occ)
$def = $occ.Definition
# it is part component and just created
if ($def.Type -eq 0x5000200 -and $def.Document.FileSaveCounter -eq 0)
if ($def.Features.Count -eq 1)
# it is the single only feature of the part
$feat = $def.Features[1]
# it is a ReferenceFeature derived from a part and is a solid body
if ($feat.ReferenceComponent.Type -eq 0x500A700 -and $feat.ReferencedEntity.IsSolid)
return $true
return $false
function SetDocumentProperty($doc, $propSetName, $propName, $propVal)
$propSet = $doc.PropertySets[$propSetName]
$prop = $propSet | Where-Object DisplayName -EQ $propName
if ($prop)
$prop.Value = $propVal
else
$null = $propSet.Add($propVal, $propName)
And in Inventor.cfg:
<?xml version="1.0" encoding="utf-8"?>
<Configuration>
<PathDefinition>{Workspace}\{Prop[Folder].Value}</PathDefinition>
<FileNameDefinition>{Prop[DocNumber].Value}</FileNameDefinition>
<PropertyDefinitions>
<PropertyDefinition PropertyName="DocNumber" DataType="Text" InitialValue="{PathAndFileNameHandler.FileName}" />
<PropertyDefinition PropertyName="Title" DataType="Text" InitialCopyValue="{UIString[CFG1]} {Prop[Title].Value}" />
<PropertyDefinition PropertyName="Description" DataType="Text" />
<PropertyDefinition PropertyName="Comments" DataType="Text" />
<PropertyDefinition PropertyName="Folder" DataType="Text" InitialValue="." RequiresValue="true"/>
<PropertyDefinition PropertyName="Original" DataType="Text" InitialCopyValue="{PathAndFileNameHandler.OriginalFullFileName}" />
</PropertyDefinitions>
<!--Add INEST to the SupportedFileTypes if you want VDS to handle the .inest files-->
<SupportedFileTypes>IDW,IAM,IPT,IPN,DWG</SupportedFileTypes>
<ShowCheckInDialog>True</ShowCheckInDialog>
<SkipForProperties>SkipVDS</SkipForProperties>
</Configuration>
in Default.ps1:
InitializeCategory
InitializeNumSchm
'InventorWindow'
'AutoCADWindow'
return $true
return $false
if ($prop)
else
<Configuration>
</Configuration>
Thanks sir @smilinger
That is good ideas. I will try it!!!
I'm aslo skipVDS by custom properties. I create a new template with skipVDS custom properties for part file. Therefore, I just edited the code in Inventor.cfg.
