Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Vault Data Stand workflow for multi-body?
3 REPLIES 3
Dai_Tech
303 Views, 3 Replies
Dai_Tech
Hello Masters,
I have some problems with Vault Data Stand. When making components, Vault is generated the filenames with correct number scheme. Then saving the .iam => Datastand regenerate the filenames (For all documents). Btw, I must click OK for all documents (I don't want to fill anymore properties. I am using vault datastand because it helps to auto select categories and number scheme). See attached video to understand more!!!
How to custom that? What is the best workflow for working between Datastand and multibody files?
Thank everyone.
Hello Masters,
Thank everyone.
3 REPLIES 3
Dai_Tech
in reply to: Dai_Tech
Dai_Tech
Can somebody help me?
smilinger
smilinger
This is my solution, we just skip all the data standard dialogs for multi-body parts:
in Default.ps1:
function InitializeWindow
    #begin rules applying commonly
    $dsWindow.Title = SetWindowTitle
    InitializeCategory
    InitializeNumSchm
    InitializeBreadCrumb
    InitializeFileNameValidation
    #end rules applying commonly
    $mWindowName = $dsWindow.Name
    switch ($mWindowName)
        'InventorWindow'
            #rules applying for Inventor
            if ($Prop['_CreateMode'].Value)
                # the document is .iam and it is the active document
                if ($Prop['_FileExt'].Value -eq '.IAM' -and $Document -eq $Application.ActiveDocument)
                    SkipMultiBodyParts $Document
        'AutoCADWindow'
            #rules applying for AutoCAD
    $global:expandBreadCrumb = $true
# skip multi-body components
function SkipMultiBodyParts($doc)
    $occs = $doc.ComponentDefinition.Occurrences
    foreach ($occ in $occs)
        if (IsNewMultiBodyPart $occ)
            SetDocumentProperty $occ.Definition.Document 'User Defined Properties' 'SkipVDS' $true
function IsNewMultiBodyPart($occ)
    $def = $occ.Definition
    # it is part component and just created
    if ($def.Type -eq 0x5000200 -and $def.Document.FileSaveCounter -eq 0)
        if ($def.Features.Count -eq 1)
            # it is the single only feature of the part
            $feat = $def.Features[1]
            # it is a ReferenceFeature derived from a part and is a solid body
            if ($feat.ReferenceComponent.Type -eq 0x500A700 -and $feat.ReferencedEntity.IsSolid)
                return $true
    return $false
function SetDocumentProperty($doc, $propSetName, $propName, $propVal)
    $propSet = $doc.PropertySets[$propSetName]
    $prop = $propSet | Where-Object DisplayName -EQ $propName
    if ($prop)
        $prop.Value = $propVal
    else
        $null = $propSet.Add($propVal, $propName)
And in Inventor.cfg:
<?xml version="1.0" encoding="utf-8"?>
<Configuration>
    <PathDefinition>{Workspace}\{Prop[Folder].Value}</PathDefinition>
    <FileNameDefinition>{Prop[DocNumber].Value}</FileNameDefinition>
    <PropertyDefinitions>
        <PropertyDefinition PropertyName="DocNumber" DataType="Text" InitialValue="{PathAndFileNameHandler.FileName}" />
        <PropertyDefinition PropertyName="Title" DataType="Text" InitialCopyValue="{UIString[CFG1]} {Prop[Title].Value}" />
        <PropertyDefinition PropertyName="Description" DataType="Text" />
        <PropertyDefinition PropertyName="Comments" DataType="Text" />
        <PropertyDefinition PropertyName="Folder" DataType="Text" InitialValue="." RequiresValue="true"/>
        <PropertyDefinition PropertyName="Original" DataType="Text" InitialCopyValue="{PathAndFileNameHandler.OriginalFullFileName}" />
    </PropertyDefinitions>
    <!--Add INEST to the SupportedFileTypes if you want VDS to handle the .inest files-->
    <SupportedFileTypes>IDW,IAM,IPT,IPN,DWG</SupportedFileTypes>
    <ShowCheckInDialog>True</ShowCheckInDialog>
    <SkipForProperties>SkipVDS</SkipForProperties>
</Configuration>
in Default.ps1:
    InitializeCategory
    InitializeNumSchm
        'InventorWindow'
        'AutoCADWindow'
                return $true
    return $false
    if ($prop)
    else
<Configuration>
</Configuration>
Dai_Tech
in reply to: smilinger
Dai_Tech
Thanks sir @smilinger
That is good ideas. I will try it!!!
I'm aslo skipVDS by custom properties. I create a new template with skipVDS custom properties for part file. Therefore, I just edited the code in Inventor.cfg.
