Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Upgrade to 2025 ilogic
3 REPLIES 3
johan.degreef
356 Views, 3 Replies
johan.degreef
Since our upgrade to 2025, this macro won't run anymore. Can anyone hep me to find what needs to be modified? Many Thanks
Imports System.IO
GetInput :
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 000000)
If Six_Digit = "" Then
            Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
End If
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\$WorkingFolder\Documents\Standards\PTN_PART_LIBRARY\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
            Dim oFileNameNoExt As String = System.IO.Path.GetFileNameWithoutExtension(oFilename)
            If oFileNameNoExt.Contains(Six_Digit) AndAlso oFileNameNoExt.Length = 11 Then
                        Dim oOptions As Inventor.NameValueMap
                        oOptions = ThisApplication.TransientObjects.CreateNameValueMap
                        oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
                        sFilename = oFilename
                        Exit For
            End If
Next
If sFilename = "" Then
            MessageBox.Show("No matching libary file found.", "iLogic")
            Return
End If
'path from current file
Dim oActiveAssemblyfolder As String = ThisDoc.Path & "\"
'find the postion of the last backslash in the path
Dim FNamePos As Integer = InStrRev(sFilename, "\", -1)
'get the file name with the file extension
Dim oName As String = Right(sFilename, Len(sFilename) -FNamePos)
'get the file name (without extension)
Dim ShortName As String = Left(oName, Len(oName) -4)
'get extension
Dim oExt As String = Right(oName, 4)
Dim oNewName As String = ShortName & "_" & System.DateTime.Now.ToString("yyyyMdHHmmss")
Dim oPathandName As String = oActiveAssemblyfolder & oNewName & oExt
oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = ShortName
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
'Dim oOcc As ComponentOccurrence
'oOcc = oAsmCompDef.Occurrences.Add( _
'oPathandName, oMatrix)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oPathandName)
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
'oOcc.Grounded = False
'ThisDoc.Document.SelectSet.Select(oOcc)
'MessageBox.Show("New file created: " & vbLf & oPathandName, "iLogic")
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Imports System.IO
GetInput :
            Return
GoTo GetInput
End If
'hard code path
                        Exit For
            End If
Next
            Return
End If
'get extension
'save new document
oDoc.Close
'[ Place Component
' Create Matrix
3 REPLIES 3
Markus.Koechl
Hi @johan.degreef, This looks like a post targeting Inventor Customization. Anyway, in Inventor 2025, you need to declare all variables with types. This change relates to the move of the Inventor API to the .NET Core platform. This move also impacts Vault and I published detailed information in our Vault Blog: Autodesk Vault 2025 SDK - Breaking News - Under the Hood - All things PDM and PLM
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Markus Koechl
johan.degreef
That I have overlooked and installed 2025. 😞
I am no programmer, so I hope it will be an easy fix (???)
Markus.Koechl
The fix is on your side; I did not check your full code but quickly saw that "Six_Digit" or "oLibrary_Folder are not declared as String. But again - please consult the Inventor forum for more details on iLogic 2025 coding.
Markus Koechl
Markus Koechl
