Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
make STEP with job processor by ilogic function
2 REPLIES 2
sebastien_forman
314 Views, 2 Replies
sebastien_forman
Hello, is it possible to request to vault to create a STEP file using the job processor from an iLogic script?
Exactly like this post: https://forums.autodesk.com/t5/vault-customization/make-pdf-with-job-processor-by-ilogic-function/m-...
But for Step file,
@Nick_Hall I call for help from the Batman of the vault XD
I have try this, but doesn't work:
Sub Main()
    If Not isPartOrAssembly() Then Exit Sub
    Dim mVltCon As VDF.Vault.Currency.Connections.Connection
    mVltCon = VB.ConnectionManager.Instance.Connection
    If mVltCon Is Nothing Then
        MessageBox.Show("Not Logged In to Vault! - Login first and repeat executing this rule.")
        Exit Sub
    End If
    Dim oDoc As Document = ThisApplication.ActiveEditDocument
    Dim oVltDocLatest As AWS.File = GetLatestVaultFile(oDoc.FullFileName, mVltCon)
    Logger.Info("File: Local Path [" + oDoc.FullFileName + "] ID [" + oVltDocLatest.Id.ToString() + "]")
    ' STEP job parameters
    Dim stepParamList As AWS.JobParam() = New AWS.JobParam(1) {}
    Dim fileIdParam As New AWS.JobParam()
    fileIdParam.Name = "FileVersionId"
    fileIdParam.Val = oVltDocLatest.Id.ToString()
    stepParamList(0) = fileIdParam
    Dim jobType As String = "Autodesk.Vault.STEP.Create" + System.IO.Path.GetExtension(oDoc.FullFileName)
    Dim jobPriority As Long = 10
    Dim jobDesc As String = [String].Format("Create STEP for {0}", oDoc.DisplayName)
    Logger.Info("Job Type: [" + jobType + "] Priority [" + jobPriority.ToString() + "]")
    AddJob(jobType, jobDesc, stepParamList, jobPriority, mVltCon)
End Sub
Function GetLatestVaultFile(VaultPath As String, mVltCon As VDF.Vault.Currency.Connections.Connection) As AWS.File
    Dim workingFolder = mVltCon.WorkingFoldersManager.GetWorkingFolder("$/")
    VaultPath = VaultPath.Replace(workingFolder.FullPath, "$\")
    VaultPath = VaultPath.Replace("\", "/")
    Dim VaultPaths() As String = New String() {VaultPath}
    Dim wsFiles() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
    Return wsFiles(0)
End Function
Sub AddJob(jobType As String, jobDesc As String, paramList As AWS.JobParam(), jobPriority As Long, mVltCon As VDF.Vault.Currency.Connections.Connection)
    Dim newJob As AWS.Job
    Try
        newJob = mVltCon.WebServiceManager.JobService.AddJob(jobType, jobDesc, paramList, jobPriority)
        Logger.Info("New Job: [" + newJob.Id.ToString() + "]")
    Catch ex As Exception
        Logger.Info("Error adding job")
        If ex.Message = "237" Then
            MessageBox.Show("Error adding job: job already exists", "Add Job", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
        Else
            MessageBox.Show("Error adding job: Unknown error", "Add Job", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End If
    End Try
End Sub
Function isPartOrAssembly() As Boolean
    ' Checks if the active document is a part or assembly.
    If ThisDoc.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Or ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        isPartOrAssembly = True
    Else
        isPartOrAssembly = False
    End If
End Function
But for Step file,
Sub Main()
        Exit Sub
    End If
End Sub
    Return wsFiles(0)
End Function
    Try
        Else
        End If
    End Try
End Sub
    Else
    End If
End Function
2 REPLIES 2
Nick_Hall
Hi Sébastien
The error is in this line
Arrays are zero-based, so for 1 parameter the declaration is
Dim stepParamList As AWS.JobParam() = New AWS.JobParam(0) {}
You should probably pass 3 parameters to match the way Autodesk do it
The extra ones are
UpdatePdfOption = False
UpdateViewOption = False
Nick
Hi Sébastien
The extra ones are
Nick
sebastien_forman
Thank you very much @Nick_Hall , that work now.
Have a nice day.
Here is the code corrected:
' Add necessary references to interact with Autodesk Vault
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDFV = Autodesk.DataManagement.Client.Framework.Vault
AddReference "Autodesk.DataManagement.Client.Framework.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
' Main procedure starts here
Sub Main()
    ' Check if the active document is an IPT or IAM file
    If Not isIptIam() Then
        MsgBox("This function must be executed in an IAM or IPT file")
        Exit Sub
    End If
    ' Get the Vault connection
    ' Check if the connection to Vault is established
        Exit Sub
    End If
    ' Get the active document in Inventor
    ' Get the latest file version from Vault
    ' Prepare parameters for the STEP job
    Dim stpParamList As AWS.JobParam() = New AWS.JobParam(2) {}
    ' Set the FileVersionId parameter
    stpParamList(0) = fileIdParam
    ' Set the UpdateViewOption parameter
    Dim updateViewParam As New AWS.JobParam()
    updateViewParam.Name = "UpdateViewOption"
    updateViewParam.Val = "false"
    stpParamList(1) = updateViewParam
    ' Set the UpdatePdfOption parameter
    Dim updatePdfParam As New AWS.JobParam()
    updatePdfParam.Name = "UpdatePdfOption"
    updatePdfParam.Val = "False"
    stpParamList(2) = updatePdfParam
    ' Define the job type and description for creating a STEP file
    Dim jobDesc As String = [String].Format("Create STP for {0}", oDoc.DisplayName)
    ' Add the job to Vault
    AddJob(jobType, jobDesc, stpParamList, jobPriority, mVltCon)
End Sub
' Function to get the latest file version from Vault
    Return wsFiles(0)
End Function
' Function to add a job to Vault
Sub AddJob(jobType As String, jobDesc As String, stpParamList As AWS.JobParam(), jobPriority As Long, mVltCon As VDF.Vault.Currency.Connections.Connection)
    Try
        newJob = mVltCon.WebServiceManager.JobService.AddJob(jobType, jobDesc, stpParamList, jobPriority)
        Else
        End If
    End Try
End Sub
' Function to check if the active document is an IPT or IAM file
Function isIptIam()
    ' Checks if the active document is an IPT (part) or IAM (assembly) file.
    If ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or ThisDoc.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
        isIptIam = True
    Else
        isIptIam = False
    End If
End Function
Have a nice day.
Sub Main()
        Exit Sub
    End If
        Exit Sub
    End If
End Sub
    Return wsFiles(0)
End Function
    Try
        Else
        End If
    End Try
End Sub
Function isIptIam()
        isIptIam = True
    Else
        isIptIam = False
    End If
End Function
