Make Parametrically Driven Properties Visible but Read-Only in Inventor Data Sheet
pmartick
pmartick
Inventor Professional ver. 2023.4.2 and Vault Professional 2023.4.2
I am learning about and working on customizing Vault Data Standard to be used by my team.  On some of our templates the Part Number and Description are parametrically driven:
When they are parametrically driven, the property becomes Hidden in the Vault Dynamic Properties Grid/Datasheet in Inventor, but still visible in Vault.
(Description should be between Part Number and Wear Part)
In case anyone asks, I do have the Description property mapped to this Category in Vault and have it listed and set to visible in DynamicProperties XML files:
Can someone point out where the logic is that automatically determines parametrically driven properties to be hidden?
I've seen on some older forum posts that making a property Read-Only in the dynamic properties grid is not possible.  Is that still true today?
The best case scenario is to make the parametrically driven properties visible but read-only.
If this isn't possible then I'll take a look in the Ideas forums to help make this possible.
Thanks for your help.
Markus.Koechl
You can set Dynamic Category Properties ReadOnly or disable editing by extending the XAML file. You can review a sample for both here: VDS-Sample-Configurations-2024/VDS-MFG-Sample/CAD.Custom/Configuration/Inventor.xaml at master · koe.... Navigate to line #132 for ReadOnly or line #107 for IsEditable.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
pmartick
Those 2 things are good to know for the future. It seems to be an all or nothing approach if I can't change the ReadOnly or IsEditable variables dynamically via the dynamic property xml files or programming it in the powershell script.
None of these that I tried worked in the powershell:
$dsWindow.FindName("Part Number").IsReadOnly = $true
$dsWindow.FindName("Part Number").IsReadOnly = "True"
So this may be useful for properties you want on permanent read-only and only changed via programming or admin-only purposes.
What about the initial problem of making the property visible when the iProperty is parametrically driven, is there no way around that?
Markus.Koechl
Hi @pmartick, I am sorry I missed getting back on your latest question/line: there is no workaround to hide these driven properties, it is "hard coded". So I suggest submitting an idea post.
Markus Koechl
