Is Vault Base (Basic) API supported?
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
Short question:
Is it possible to create Vault Extensions (Vault add-in) for Vault Base (Basic) 2020?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
 Is this still true for Base Vault (Basic Vault), found in the Help files?
"There are various ways to customize Vault Explorer through the API.  You can...
  • Add custom commands.
  • Add custom tabs.
  • Hide existing commands.
  • Subscribe to pre and post events when any Vault Explorer commands are executed.
Availability
This feature is not available in base Vault.  Vault Workgroup, Vault Collaboration or Vault Professional is required."
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Hoi,
@psaarloos
Heb jij een idee hierover?
Dank je alvast,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
psaarloos
Hi Authur,
No, it's not possible to create an extension for the Vault Basic product. The Vault SDK Help mentions the following:
Add custom tabs.
Availability
Hope this helps.
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
bradeneuropeArthur
Thank you! @psaarloos
No workarounds?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
