I am looking for a way to get the value from a specific property of a file I know that is in the Vault.
The following code is working. At the end I placed a comment on where the value of the property "Category Name" should be looked up in the file that was found.
Thanks in advance for any help.
public bool CheckFileExistsInVault(string vaultFileName)
WindowsIdentity windowsIdentity = WindowsIdentity.GetCurrent();
var userName = windowsIdentity.Name;
var password = "";
var serverName = "xx.x.xx.xx";
var vaultName = "Vault";
VDF.Vault.Results.LogInResult results = null;
try
results = VDF.Vault.Library.ConnectionManager.LogIn(serverName, vaultName, userName, password, VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, null);
catch
return false;
if (!results.Success)
MessageBox.Show("Unable to login to the Vault.", "Login Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
return false;
VDF.Vault.Currency.Connections.Connection connection = results.Connection;
VDF.Vault.Currency.Entities.Folder rootFolder = connection.FolderManager.RootFolder;
VDF.Vault.Currency.Entities.FileIteration fileIteration = null;
try
fileIteration = GetFileIteration(vaultFileName, connection);
catch
VDF.Vault.Library.ConnectionManager.LogOut(connection);
return false;
if (fileIteration == null)
return false;
else
//get value of property "Category Name" here
return true;
return false;
var password = "";
try
catch
return false;
return false;
try
catch
return false;
return false;
else
return true;
return false;
Solved by Nick_Hall. Go to Solution.
Hi Gert
You won't be able to get the Category Name where you have indicated, because in the line above you are logging out of Vault
But at line 30, you can get the Category Name of the file using something like this
string[] filePaths = { vaultFileName };
File[] files = connection.WebServiceManager.DocumentService.FindLatestFilesByPaths(filePaths);
string categoryName = files[0].Cat.CatName;
Hope that helps
Nick
Hi Gert
Hope that helps
Nick
@Nick_Hall, you are right. That should of course be done before logout.
My question is: what part of the api do I need to call to get a specific property? In your example, you only get the latest created file in the Vault, but in our case, this won't work, because multiple files can be created at the same time by multiple users. I need it to be specific the file that the user is working on.
In the code, you need to set the variable vaultFileName to the full Vault path of the file you want to get
FindLatestFilesByPaths returns the latest/current version of the file(s) you specify in the argument
What type of application are you creating - Vault add-in, AutoCAD add-in, stand-alone EXE, something else?
If you let me know I can give you better guidance
Nick
Nick
Ok. I think I understand. Not sure if I can start on it today, otherwise after the weekend.
It is an addition for an Inventor add in. This add in lets user fill in easy all the necessary properties that we need in the Vault, but right now we have to do a check on the Category Name.
I implemented the code as per your instruction, but categoryName gives me an empty string.
try
Autodesk.Connectivity.WebServices.File[] files = connection.WebServiceManager.DocumentService.FindLatestFilesByPaths(filePaths);
MessageBox.Show("Category Name = " + categoryName);
In this, for this particular file, Category Name should give me
Is CatName the same as Category Name?
try
I've tested this out and come up with this working code (apologies for using PowerShell, but it is very similar to C#
$serverIdentities = New-Object Autodesk.Connectivity.WebServices.ServerIdentities
$serverIdentities.DataServer = "192.168.1.100"
$serverIdentities.FileServer = "192.168.1.100"
// License model
$licenseType = [Autodesk.Connectivity.WebServices.LicensingAgent]::Client
// Login
$cred = New-Object Autodesk.Connectivity.WebServicesTools.UserPasswordCredentials($serverIdentities, "Vault", "Administrator", "*****", $licenseType)
$webSvc = New-Object Autodesk.Connectivity.WebServicesTools.WebServiceManager($cred)
// Full file path in Vault
[string]$vaultFileName = '$/Job PDFs/1017178/Manuals/1017178_ManualList.pdf'
// FindLatestFilesByPaths needs an array of strings
[string[]]$filePaths = ( $vaultFileName )
// Get the file
[Autodesk.Connectivity.WebServices.File[]]$files = $webSvc.DocumentService.FindLatestFilesByPaths($filePaths)
// FindLatestFilesByPaths returns an array of files, so we only want the first
[Autodesk.Connectivity.WebServices.File]$file = $files[0]
// The file has the cathegory name in Cat.CatName
[string]$categoryName = $file.Cat.CatName
Write-Host "File Path : [$($vaultFileName)]"
Write-Host "File Name : [$($file.Name)]"
Write-Host "Category Name: [$($categoryName)]"
This produces the following output
File Path : [$/Job PDFs/1017178/Manuals/1017178_ManualList.pdf]
File Name : [1017178_ManualList.pdf]
Category Name: [PDF Documentation]
Looking at the file in Vault
This code was tested on Vault 2021, but should be OK for 2022 & 2023
Looking at the issue you are having, I suspect that getting an empty string for categoryName is caused by not getting the file correctly. That happened when I was testing, and it was because I had a typo in the file name (line 10)
Hope it makes things a bit clearer
Nick
// License model
// Login
// Get the file
Nick
I think I found out why it is not working. The variable vaultFileName in my case is just a string in the form xxx.ipt. So no file path. It has to be the path in Vault, thanks to your last reply.
I now got it working to change it to this:
try
vaultFileName = "$/xxxx/Documents/" + vaultFileName;
Autodesk.Connectivity.WebServices.File file = files[0];
string categoryName = file.Cat.CatName;
MessageBox.Show("File Path = " + vaultFileName +
"\nFile Name = " + file.Name +
"\nCategory Name = " + categoryName);
This is the result:
I now have to figure out how to get the file path, but that is not much of an issue.
Thank you very much!
try
This is the result:
