Is there a way to define the default settings for Copy Design? I didn't find it in the menus, but it has to be defined somewhere. In short I want to default NOT including related documentation and attachments, and I want the dialogue to show the file tree view by default.
It would also be great if the default "Copy from" directory was the directory of the file I'm preforming the operation on, and the "copy to" directory was defaulted the last one used by the command. And it would be REALLY awsome if the default copy/reuse state could be defined by directory; such as everything in the same folder, including sub folders, as the IDW I'm copying gets defaulted to "copy", while everything else is defaulted to "reuse". I'm starting to think that implementing Vault and all its functionality in the iLogic concept might not be a bad idea...
