- Mute
- Permalink
- Report
Hello!
Below question is related to saving IDW files referencing the same IPT or IAM model, given that Vault Pro is set to "Enforce Unique Filename".
Some situations request a single model (IPT, IAM) to be the reference of several drawings (IDW).
For example:
-one drawing intended for manufacturing, displaying the necessary dimensions or informations,
-one drawing intended for customer, only displaying the overall dimensions.
Here is the case:
From a model reference 1234.ipt or 1234.iam, when placing the 1st view onto a 1st IDW file, this IDW filename is automatically renamed according to the model reference filename, i.e. 1234.idw.
In VDS, the filename is set to 1234.idw. The IDW file can be saved. Up to here, all works fine.
From the same model reference, when placing the 1st view onto a 2nd new IDW file, this IDW filename is automatically renamed according to the model reference filename, i.e. again 1234.idw.
In VDS, the filename is again set to 1234.idw. As Vault is set to "Enforce Unique Filename", it is of course impossible to save the file. The filename can be set manually in the VDS textbox, however it would be out of the Numbering Scheme defined in Vault.
Should I give up with the possibility of several drawings based on the same model reference?
Or should I reconsider the scenarii?
This question is closely linked to this topic still unanswered:
Best regards,
Leon
