VBA code in excel to check in file
pr.nordin
Observer Observer
pr.nordin
Observer
Observer
Is there any way to write vba code in excel to check in file to vault.
I have Vault office add-in but want to do this with vba coding.
Nick_Hall
Unless they have made any massive changes to Excel VBA recently, you will need to write a COM wrapper for the Vault API functions you need
There's an old example for from 2017 that should get you started, but you'll definitely need to make changes to the login code, as that has changed a lot in recent years
https://forums.autodesk.com/t5/vault-customization/reading-vault-files-properties-inside-excel-vba/t...
Hope that helps
Nick
