Close files and delete working copies
JRajendran4
JRajendran4
Is there a way to stop deleting local files after restricting it from check-in(Even "Close files and delete working copies" is checked)?
I have some conditions before checking in files to vault server from Inventor. If the file checkin fails it should not delete local file.How to handle it by C# code?
The below code is used to add restriction in "AddFileEvents_GetRestrictions" Event.
How to handle the deletion of files if checkin is not happened using c#?
Thanks in advance
Nick_Hall
Hi
Two things
Firstly, your snippet only shows an AddFile restriction, but no CheckinFile restriction - if this is not implemented, it might be causing your issue
Secondly, if you do have a CheckinFile restriction you seem to be saying that when you ...
  • Set the "Close files and delete working copies" option
  • Click OK in the check-in dialogue box
  • Raise the restrictions in your add-in
... the check-in is restricted, but the files are closed & deleted
This should cancel the check-in, and do nothing further, so what is happening isn't correct operation & should be reported as bug
Hope some of that is helpful
Nick
JRajendran4
Hi Nick,
Thanks for your thoughts!
1) Yes, there is a implementation for CheckinFile restriction too.
2) As per your point, Yes, the check-in is restricted, but the files are closed & deleted so it should be a bug and will report it
Jayapriya
