Perform a property sync
A.WagnerKWWFA
A.WagnerKWWFA
After copying a file and changing some user properties using the code
mUploadTicket = fileStoreService.CopyFile(fileDownloadTickets[0].Bytes, mExt, true, prpRequests, out mResults);
Autodesk.Connectivity.WebServices.File mNewFile = documentService.AddUploadedFile(...)
the new file has a system property mismatch at Author and CreationDate.
Is there a way to perform a property sync (see attachment) so that the new Author and the new Date are written to the File?
Markus.Koechl
I suggest changing the order if you changed the properties between the two steps of copying and adding the new file. Update the properties right after the upload. Compare the code sample posted here: https://github.com/koechlm/iLogic-Vault/blob/2023/iLogic-Vault-QuickstartLibrary/iLogic-Vault%20Quic... and ff.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
