Vault Data Standard - Sample Configuration Quickstart 2017.1 available
Markus.Koechl
Autodesk Autodesk
Markus.Koechl
In several posts, I mentioned a "Quickstart" sample configuration available via Autodesk Reseller Channel in EMEA. With our 2017.1 version, this sample went public in Autodesk Knowledge Network. Follow the link to download documentation and configuration packages.
https://knowledge.autodesk.com/community/article/35881
Currently, en-US and de-DE configuration languages are available.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
tolgay.hickiran
Hello Markus Merry Christmas,
We've downloaded the VDS and updated to .1 version but we don't get to see the quick menus like organisations or tasks. Do we need to do something else after downloading, doing the setup and updating?
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
Markus.Koechl
In regards to your later post http://forums.autodesk.com/t5/vault-customization/numbering-is-not-done-in-data-standard/td-p/679146... that already shows that you succeeded to enable the custom objects, I think this thread could be closed. Can you confirm that you just missed to have the custom object definition for task, person, organization and transmittal in your vault?
Markus Koechl
tolgay.hickiran
Yes Markus,
We've successfully started using the Quickstart thanks
Tolgay Hickiran
Founding Partner
SignatureSignature
website
