Prevent Command Execute by using CommandBegin Event
gbadziura
gbadziura
Hi All
I'm trying to prevent a command execution by using the CommandBegin event, but it seems, that there is no cancle or handled property to stop the execution.
I Need this because not for all Commands exist an Event like Checkin or Check out.
Anyone has an idea???
Regards
Gerhard
wayne.brill
Hi Gerhard,
Which commands are you trying to cancel?
This post discusses using multiple events (not sure if it will help)
http://justonesandzeros.typepad.com/blog/2011/09/vault-explorer-command-events.html
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
gbadziura
Hi Wayne
I want to have the possibility to cancle every UI Command depending on diffrent conditions. So, for example, i am able to prevent renaming of files if the user is member of an certain Group. He must have the right to Change files but with this he ist not able to use the rename command.
Hope this makes it a little bit more clear.
regards Gerhard.
P.S. I tried to throw an exeption but the command was not influenced by this.
wayne.brill
Hi Gerhard,
Could you use the DocumentService.CheckoutFileEvents.GetRestrictions and restrict the checkout if the user does not meet the requirement?
I used this example to test and when I renamed a file. It was restricted when I had the "CheckoutFile Command" clicked. (using the Configurator project in the solution)
C:\Program Files (x86)\Autodesk\Autodesk Vault 2016 SDK\vs12\CSharp\RestrictOperations
Currently there is not a way to cancel the command with the IApplication.CommandBegin event. You could request it on the Vault Idea Station:
https://forums.autodesk.com/t5/vault-ideas/idb-p/2/tab/most-recent
Wayne
Wayne Brill
gbadziura
Hi Wayne
Rename was just an example. WebserviceEvents is not in every case a soulution. What i dont understand is, why are the events implemented if i am only able to do something bevor and after without the possibility to influence the command itself.
So i put it to the IdeaStation.
Regards
Gerhard
