- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I want to fill out the main and required properties by using Vault Data Standard, but I don't want to enter the path and/or filename via Data Standard. Then, I'd like to add a Browse button on the Vault Data Standard dialog box or would like to get the Save As dialog box after having filled out all the properties and having pressed OK. Is this possible?
By default, if a remove the path and filename of the Vault Data Standard, it saves the file in the Workspace location without requesting a user-specified location. I'd like to specify the location manually. The reason why I want to do this is because the Vault folder structure has a lot of levels (subfolders) and it is also kind of complex.
Thanks!
