Vault 2016 api C# add item soap exception 155
 I am trying to add a new item
using the following code and i am getting soap exception 155
try
                using (GV.wServ = GV.connection.WebServiceManager)
                    var cd = (Global.CategoryData)cBox_ItemMasterCategoryList.SelectedItem;
                    var ns = (Global.NumSchemes)cBox_ItemNumScheme.SelectedItem;
                    ItemService IS = GV.wServ.ItemService;
                    var item = IS.AddItemRevision(cd.CatID);
                    ProductRestric[] pres = new ProductRestric[1];
                    long[] mID = { item.MasterId };
                    long[] sID = { ns.SchemeID };
                    getItemNum();
                    ItemNum[] newNumbers = IS.AddItemNumbers(mID, sID, ItemNSFieldInputs, out pres);
            catch(SoapException se)
                MessageBox.Show(se.ToString());
            catch (System.Exception ex)
                MessageBox.Show(ex.ToString());
This is the line I am getting the error
Update:
The issue with the FieldInputs
Names Scheme items having isssues
autogeneration - store - "" to field array
FreeText - Not working if we pass the freetext value in to the field array
 newItemNum = new string[] { TextBox_obj.Text };
                                    tempArr = new StringArray();
                                    tempArr.Items = newItemNum;
                                    ItemNSFieldInputs[index] = tempArr;
Delimiter - Ignore - No need to pass anything in the field array
FixedText - Ignore - No need to pass anything in the field array
Workgroup Ignore - No need to pass anything in the field array
PredefinedList - Not working if we pass the list value in to the field array
newItemNum = new string[] { ComboBox_obj.SelectedItem.ToString() };
How do I pass the free text value and the predifined listvalue to the field array which then can be passed to
