Vault 2017 - Login Error
Micky_SDP
Micky_SDP
Hi everybody, here is my problem. If I try to use Vault 2017 SDK into Autocad (OEM) 2016, when I do something on Vault Login Windows appears this message: Unable to find assembly Autodesk.Connectivity.WebService.Interop 22.0.0.0 Is Vault 2017 SDK compatible with Autocad 2016? I attach the screenshot.. Regards, Michele
AlexFielder
Hi @Micky_SDP,
If I understand things correctly, you would need to use the Autodesk Vault 2016 SDK to work alongside AutoCAD 2016.
The 2016 SDK should be able to talk to Vault 2017 in the same way that the 2015/2016 Vault clients can.
Alex.
Micky_SDP
Hi @AlexFielder, I try to use the Autodesk Vault 2016 SDK and when I call the Login Windows appears this error: autodesk.data management.client.framework.vault.forms.Library throw an ecception I think the problem is that on the PC is not installed into the Vault Client 2016 but only the Vault Client 2017. Regards, Michele
I don't know if this will help, but I was having an issue logging into Vault with the 2017 dll files. My code would work fine with the 2016 dll files, but then not work when I updated them to 2017. After many hours of trying things, this is what I did that I think fixed the problem.
I added a reference to the Autodesk.Connectivity.WebServices.Interop.dll and Autodesk.Connectivity.WebServices.WCF.dll. I also tried to add a reference to the clmloader.dll but for some reaason it wouldn't let me. But I copied the clmloader.dll and added it to my project bin folder and then my connection issues went away.
Chad
AlexFielder
Thanks @Anonymous for the tip on the Autodesk.Connectivity.WebServices.WCF reference.
My Addin still doesn't log in, but I'll report back to the other thread I have concerning this and ask Autodesk for feedback.
Cheers,
Alex.
Micky_SDP
Thanks @chad.salmela for the help..
Your solution works fine...
Cheers,
Michele
