Hello All,
I'm writing an automation for Autocad. I need my application to check in an active documents file and stay checked out.
I wrote the following code using the examples. But it fails to check in the file into Vault. Can anyone help me with my problem.
public static void CheckIn(string fileName)
VDF.Vault.Results.LogInResult login_results = VDF.Vault.Library.ConnectionManager.LogIn(Settings.VAULT_IP, Settings.VAULT_NAME, Settings.VAULT_USER, "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, null);
VDF.Vault.Currency.Connections.Connection conn = null;
if (login_results.Success)
conn = login_results.Connection;
else
MessageBox.Show("Couldn't login");
return;
var fileIteration = getFileIteration(fileName, conn);
//check if file Exists
if (!System.IO.File.Exists(fileIteration.CheckedOutSpec))
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("The file you are attempting to check in does not exist on disk.");
VDF.Vault.Library.ConnectionManager.LogOut(conn);
return;
if (fileIteration.IsCheckedOut)
conn.FileManager.CheckinFile(fileIteration, "Take off update", true, new Autodesk.Connectivity.WebServices.FileAssocParam[] { }, null, false, fileName, fileIteration.FileClassification, false);
} private static FileIteration getFileIteration(string fileName, Connection conn)
SrchCond[] conditions = new SrchCond[1];
long lCode = 1;
var Defs = conn.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE");
PropDef Prop = null;
foreach (var def in Defs)
if (def.DispName == "File Name")
Prop = def;
break;
var searchCondition = new Autodesk.Connectivity.WebServices.SrchCond();
searchCondition.PropDefId = Prop.Id;
searchCondition.SrchOper = lCode;
searchCondition.SrchTxt = Path.GetFileName(fileName);
conditions[0] = searchCondition;
List<Autodesk.Connectivity.WebServices.File> fileList = new List<Autodesk.Connectivity.WebServices.File> ();
String sBookmark = "";
SrchStatus Status = null;
Autodesk.Connectivity.WebServices.File[] files = null;
while(Status == null || fileList.Count < Status.TotalHits)
files = conn.WebServiceManager.DocumentService.FindFilesBySearchConditions(conditions, null, null, true, true, ref sBookmark, out Status);
if (files != null)
fileList.AddRange(files);
VDF.Vault.Currency.Entities.FileIteration oFileIteration = new VDF.Vault.Currency.Entities.FileIteration(conn, fileList[0]);
return oFileIteration;
}I get the following error message:
{System.Web.Services.Protocols.SoapException: 1108
at Autodesk.Connectivity.WebServices.DocumentSvc._DocumentService.Execute(String methodName, Object[] parameters, IWebServiceCommandEventsCollection events, WebServiceCommandEventArgs args)
at Autodesk.Connectivity.WebServices.DocumentService.CheckinUploadedFile(Int64 fileMasterId, String comment, Boolean keepCheckedOut, DateTime lastWrite, FileAssocParam[] associations, BOM bom, Boolean copyBom, String newFileName, FileClassification fileClassification, Boolean hidden, ByteArray uploadticket)
at Autodesk.DataManagement.Client.Framework.Vault.Services.Connection.Implementation.FileManager.CheckinFile(FileIteration file, String comment, Boolean keepCheckedOut, DateTime lastWrite, FileAssocParam[] associations, BOM bom, Boolean copyBom, String newFileName, FileClassification classification, Boolean hidden, Stream inputStream)
at Autodesk.DataManagement.Client.Framework.Vault.Services.Connection.Implementation.FileManager.CheckinFile(FileIteration file, String comment, Boolean keepCheckedOut, FileAssocParam[] associations, BOM bom, Boolean copyBom, String newFileName, FileClassification classification, Boolean hidden, FilePathAbsolute filePath)
at CWVDuctImport.VaultInterface.CheckIn(String fileName) in H:\cwv-mobile-client\src\acad\cwvtools\vaultinterface.cs:line 195
at CWVDuctImport.Commands.cwv_iterate() in H:\cwv-mobile-client\src\acad\cwvtools\commands.cs:line 1161
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()}
