user properties not mapping in new 2020 vault
JasonMayes
Message 1 of 16
JasonMayes
Upgraded from Vault Pro 2018 to Vault Pro 2020. Created new server, copied over current back up, restored back up, and mapped all 2020 software to the 2020 Vault. Our cad file title block attribute fields were/are mapped to user properties in the Vault. In 2018 we had no issues but in the new 2020 these are not mapping. I have been told by users that if they do a drawing then purge it that the properties will then map. This is not an acceptable workflow. Any ideas on what would cause this or how to fix it?
Replies (15)
Message 2 of 16
JasonMayes
@Senthil_Kumar  @ihayesjr
more details
Inventor part, assembly, IDW files map fine
Autocad Mechanical file only map when "blocks" are purged from drawings.
Thank you for any help,
Jason
Message 3 of 16
ihayesjr
@JasonMayes Have you installed 2020.1 Update yet?
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 4 of 16
JasonMayes
@ihayesjr  Yes, both the server and clients are on the 2020.1 update. Acad and Inv are also current on updates.
Message 5 of 16
ihayesjr
Can you explain what you mean by
What are they doing when you say "purge"?
Irvin Hayes Jr
Autodesk, Inc.
Message 6 of 16
JasonMayes
@ihayesjr I have attached a word doc. Please take a look.
Message 7 of 16
ihayesjr
Inside of AutoCAD, what file version are you saving the files in? 2013 or 2018?
Also, can you give me a screen shot of the mapping?
Irvin Hayes Jr
Autodesk, Inc.
Message 8 of 16
JasonMayes
Message 9 of 16
ihayesjr
Can you verify that the title block is set in the ADMS Console for indexing?
Irvin Hayes Jr
Autodesk, Inc.
Message 10 of 16
JasonMayes
Message 11 of 16
JasonMayes
How can I verify that?
Message 12 of 16
JasonMayes
Message 13 of 16
ihayesjr
Yes, I am wondering if there is some type of priority of the mappings that might be causing the problem.
I see that you have created a support case, I think it would be easier for them to troubleshoot with you them me trying to over the forum.  It is strange that the purge command is necessary or that it actually causes it to get the properties in.
Irvin Hayes Jr
Autodesk, Inc.
Message 14 of 16
Patrick.De.Neef
Hello Jason
can you verify the following:
check if the folder C:\Program Files\Autodesk\ADMS Professional 2020 \Server\Components contains a file named FilterConfig.xml
If not, I hope you can recover it from your old installation. If so, just copy it over and try the check in again
the contents of the file is something like this
<FilterConfig>
<DWG>
<Block Name="NAME OF TITLEBLOCK 1" GUID="{806a4797-b888-4d75-b2c4-4efee056ad1f}" InUse="1" ExtractAttributePrompt="false" />
<Block Name="NAME OF TITLEBLOCK 2" GUID="{3385e002-f5d1-4583-8c26-b4dc74ede8bc}" InUse="1" ExtractAttributePrompt="false" />
</DWG>
</FilterConfig>
Patrick
Message 15 of 16
JasonMayes
@Patrick.De.Neef
I have compared both xml files and they are identical. Still not sure what is going on with them not mapping until the dwg has been purged. Inventor file properties are mapping fine and once the dwg has been purged it will map.
Message 16 of 16
reidmatthew
Autodesk Support
Autodesk Support
@JasonMayes  and I have looked into this. It appears that one specific nested block in his drawings is the cause of the failed mapping. We are continuing to investigate this behavior internally. Here is a link you can use to see the progress or status of the investigation:
Unable to map properties from an AutoCAD DWG to Vault until certain blocks are purged from the DWG
Note: marking this as a solution so other users can find this and that there is an investigation
Matt R.
Product Support Specialist, Data Management
