Method to get Custom Entity Properties thru API
Eli_Dexter
Message 1 of 11
Eli_Dexter
How do I get Custom Object Properties in Powershell with PowerVault using API call.
I have looked thru SDK documentation and could not find in CustomEntityService any Methods that let me get the Properties of the Custom Object and their Values.
Interestingly, there is UpdateCustomEntity method to update Custom Objects. But before Update  I would like to check if update is required.
Replies (10)
Message 2 of 11
dave_taylor
If you are using coolOrange powerVault, you can get the file like this and then get the property needed:
# get the file
$file = Get-VaultFile -File '$/Designs/Part01.ipt'
# get the property needed
$propCustom = $file.'CustomPropName'
Check here: https://doc.coolorange.com/projects/powervault/en/stable/code_reference/commandlets/
Items are a similar method. Check the commandlet reference with the link above.
Dave Taylor
MCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
Message 3 of 11
Eli_Dexter
The question was not about file properties but Custom Object properties. Unfortunately, CoolOrange practically does not support Custom Objects.
Message 4 of 11
Markus.Koechl
You can retrieve properties of custom objects as shown here:
#retrieve property value given by displayname from Custom Object (ID)
function mGetCustentPropValue ([Int64] $mCentID, [STRING] $mDispName)
	$PropDefs = $vault.PropertyService.GetPropertyDefinitionsByEntityClassId("CUSTENT")
	$propDefIds = @()
	$PropDefs | ForEach-Object {
		$propDefIds += $_.Id
	$mPropDef = $propDefs | Where-Object { $_.DispName -eq $mDispName}
	$mEntIDs = @()
	$mEntIDs += $mCentID
	$mPropDefIDs = @()
	$mPropDefIDs += $mPropDef.Id
	$mProp = $vault.PropertyService.GetProperties("CUSTENT",$mEntIDs, $mPropDefIDs)
	$mProp | Where-Object { $mPropVal = $_.Val }
	Return $mPropVal
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Message 5 of 11
Eli_Dexter
Message 6 of 11
J_Dumont
Hi Markus,
I am trying to use the code in your example but getting errors. Any help would be greatly appreciated.
The code needs to retrieve a UDP from the custom object called "RTE_Creator." In this case, it's an email that I will use to send an email.
Here's my function:
	$propDefIds = @()
	$mEntIDs = @()
	$mPropDefIDs = @()
	Return $mPropVal
        elseif ($customObject._NewState -eq "Approved" -and $customObject._State -eq "Review"){
            $subject = "An RTE State was Changed: "
            $body = "An RTE was just Approved: " + $RTENumber
            $RTECreatorEmail=mGetCustentPropValue($customObject, "RTE_Creator")
Here's the error
Message 7 of 11
Markus.Koechl
@J_Dumont, you need to hand over the custom objects Id, not the custom object.
$RTECreatorEmail=mGetCustentPropValue($customObject.Id, "RTE_Creator")
Markus Koechl
Message 8 of 11
J_Dumont
Hi Markus,
My apologies. That's what I tried first, and I got the same error.
I am able to show I have a value for $CustomObject.Id as shown below.
Message 9 of 11
Markus.Koechl
I wonder how the error could be the same if $mCentID is the custom entity (object) or the ID (int64).
Markus Koechl
Message 10 of 11
dave_taylor
If you are using powerShell, send the variables to the function like this:
$RTECreatorEmail = mGetCustentPropValue $customObject.Id "RTE_Creator"
Don't use the parenthesis when calling the function with variables. I tried this and it works as it should for you...
Dave Taylor
Hagerman & Co.
Message 11 of 11
J_Dumont
Hi Dave,
Yes, your solution worked great.!!
Thank you both for replying so quickly.
