Use Vault API in ILogic to get comment of revision
Matthew_Policelli
Matthew_Policelli
How do I do this?
I currently have the file checked out. I want my iLogic to get the "Copy of file..." comment from the current revision, but as far as I can tell, <FileIteration>.comment either fails to get anything, or it gets the comment from the placeholder revision that was created when I checked out the file.
Is there no way to get the comment? Below is my code:
Function GetVaultState(ByRef LastCheckInDate As DateTime) As VDF.Vault.Currency.Entities.FileIteration
	Dim mVltCon As VDF.Vault.Currency.Connections.Connection = VB.ConnectionManager.Instance.Connection
	If mVltCon Is Nothing Then Throw New System.Exception("Not Logged In")
	'Convert File Path to Vault Path
	Dim VaultPath As String = ThisDoc.PathAndFileName(True).Replace("C:\_VaultWork\", "$/").Replace("\", "/")
	Dim awsFiles() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(New String() {VaultPath })
	LastCheckInDate = awsFiles(0).ModDate	'pass the last modified date back to the main code
	Logger.Info(LastCheckInDate.ToString("MM/dd/yyyy"))	' now I should check that this actually gives the last modified date and not the current date when the file is checked out.
	Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(mVltCon, awsFiles(0))
	Logger.Info(mFileIt.Comment)	' this gives a blank string
	Return mFileIt
End Function
Markus.Koechl
If a file is checked out, the comment is the latest text entered during the check-out command; see FileIteration -> comment property in SDK Help. So, you either need to grab the comment before you checkout or retrieve the file version current version-1 using GetFilesByVersions.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Matthew_Policelli
Sounds like get files by versions is what I want. How do I get the arguments needed for that function?
It's possible this changed with newer versions of Inventor/Vault, but with Inventor 2022 and Vault 2022, there is no description of the functions to know what the inputs should be.
Markus.Koechl
You can get the arguments for Vault API calls within iLogic Editor if you copy the XML documentation files and the referenced library. E.g.,
Alternatively - and my recommendation on top of the Intellisense option - is reviewing the SDK documentation.
And yes, Inventor 2024 integrated an iLogic-Vault library, providing Vault access through iLogic Syntax rather than directly programming Vault API calls. You can get this as a tech-preview also for 2022 here: Release iLogic-Vault | iLogic-VaultInventorServer 2022.3 · koechlm/iLogic-Vault (github.com)
Markus Koechl
Matthew_Policelli
Just to update this and close it, I did end up figuring it out based off of this. Here is the code snippet I used to check if a file was recently design copied (by checking for the "Copy of file" comment)
	Function GetVaultState(ByRef LastCheckInDate As DateTime, ByRef DesignCopyBool As Boolean) As VDF.Vault.Currency.Entities.FileIteration
		'pass file properties needing checking back to calling sub
		With awsFiles(0)
			Try
				' get the previous version's comment
				Dim PrevComment As String = mVltCon.WebServiceManager.DocumentService.GetFileByVersion(.MasterId, .VerNum - 1).Comm
				' if properties were updated by copy design, check the comment from 2 versions ago instead
				If PrevComment = "Properties updated by Copy Design."
					PrevComment = mVltCon.WebServiceManager.DocumentService.GetFileByVersion(.MasterId, .VerNum - 2).Comm
				' Check if the previous comment indicates the currently edited file is design copied.
				DesignCopyBool = PrevComment.StartsWith("Copy of file")
			Catch
				DesignCopyBool = False
			End Try
			LastCheckInDate = .ModDate	'last modified date will be the last time the file was modified before being checked into vault
		End With
... MORE CODE End Function
