Inventor VDS: Do not show the Check In Dialogue Box
Nick_Hall
Nick_Hall
Hi
When customising VDS for Inventor, is it possible to NOT show the Check In dialogue box after the VDS window has closed?
We have a situation where checking the newly-created file into Vault is not always required, and the ability to programmatically disable check-in would solve the issue.
Any help gratefully received
Nick
Markus.Koechl
Hi @Nick_Hall , the Inventor.cfg has a setting <ShowCheckInDialog>False</ShowCheckInDialog>. The default is true, and you can change it to false.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Nick_Hall
Thanks, @Markus.Koechl.
I didn't think of looking at that file. You've also reminded me of the "SupportedFileTypes" setting, which will help with another project.
Just one other thing: Is Inventor.cfg read every time the dialogue loads, or just when Data Standard is loaded?
Nick
Nick_Hall
@Markus.Koechl
You can ignore my last question. I've read the help pages properly instead of just skimming them
Nick
