- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Short explanation is i'm trying to create a method for us to import items from our very old ERP to Vault Items. I have create a test function to work from and i finally go to at least report success, but no item is getting created in Vault. Can anyone point out what exactly we're missing here? Thanks
private void TestCreateSingleItem(Connection connection)
try
Cat[] categories = connection.WebServiceManager.CategoryService.GetCategoriesByEntityClassId("ITEM", true);
long catId = -1;
foreach (Cat category in categories)
if (category.SysName == "Assembly")
catId = category.Id;
var categoryId = GetDefaultItemCategoryId(connection);
MessageBox.Show($"Found category ID: {catId}");
// Step 1: Find available numbering schemes
long numschid = -1;
NumSchm[] schemes = connection.WebServiceManager.NumberingService.GetNumberingSchemes("ITEM", NumSchmType.Activated);
foreach (NumSchm scheme in schemes)
if (scheme.Name.Contains("Item"))
numschid = scheme.SchmID;
try
// create the item
var newItem = connection.WebServiceManager.ItemService.AddItemRevision(catId);
MessageBox.Show($"Item created with ID: {newItem.Id}, MasterID: {newItem.MasterId}");
// Step 2:
var fieldInputs = new StringArray[1];
var sarray = new StringArray
Items = new string[] { "TEST-001" }
fieldInputs[0] = sarray;
// Try with numbering scheme ID = 1 (might not exist, but let's see the error)
var itemNums = connection.WebServiceManager.ItemService.AddItemNumbers(
new long[] { newItem.MasterId },
new long[] { numschid },
fieldInputs,
out ProductRestric[] restrictions);
MessageBox.Show($"AddItemNumbers succeeded! Got item number: {itemNums[0].ItemNum1}");
catch (Exception ex)
MessageBox.Show($"Error with AddItemNumbers: {ex.Message}");
// The error might tell us what numbering scheme IDs are available
MessageBox.Show($"Error: {ex.Message}");
