How to enable search bar in Vault file dialog using API?
pranit_awale
pranit_awale
I’m using the Autodesk Vault API to open a file selection dialog, and the dialog itself is working fine. However, the search bar is not visible in the dialog.
Does anyone know how to enable or invoke the search bar in the Vault file dialog through the API?
Thanks in advance!
@Markus.Koechl
Markus.Koechl
You can add the button using the extensibility options.
Be aware that you need to implement all behavior and UI behind the button. In other words, there is no default "Search" dialog that you can raise.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
pranit_awale
try
var settings = new VdfForms.Settings.SelectEntitySettings
MultipleSelect = false,
settings.OptionsExtensibility.DoSearch = (entityClassIds, multiSelect, resultFunc) =>
var searchResults = new List<Vault.Currency.Entities.IEntity>();
resultFunc(searchResults);
// 2. Open dialog
var fileDialog = VdfForms.Library.SelectEntity(VaultConnection.connection, settings);
// 3. Get selected files
var files = fileDialog.SelectedEntities.OfType<FileIteration>().ToList();
if (files.Count == 0)
MessageBox.Show("No file selected.");
return null;
// 4. Download selected files
DownloadFiles(files);
I using the above mentioned approach but not getting search bar visible.
