DuplicateQueuedEvent [237]
Anyone has already encountered the error: DuplicateQueuedEvent [237] ?
I've not found any description on why or with which conditions is raised.
Thank you in Advance
Redmond.D
So what are the conditions that raised the error in your case?
Doug Redmond
Software Engineer
I don't understand which field is considered "duplicated", it is one of the JobParam array values?
thank you
Redmond.D
You can't queue the same job twice.  If there is already a job on the queue of the same type, with the same parameters and values, you will get an error.
Is this the case you are running into?
Doug Redmond
Software Engineer
Hi Doug.
I think this could be the case, I will check.
