Vault 2012 Pro-Web Client Customization
We are trying to use SharePoint 2010 integration. Now the version of the .dwf files that it shows is the latest version. But lot of times when the files are in Work in progress state the visualization files are not available. Here we want to use the functionality that Vault web client uses. In web client in configuration screen we can check the check box saying view released revisions only. Is there a code available to do that. What Vault property is used to obtain the .dwf file from previous released revision. Or is there an alternate.
Thanks in advance!
Redmond.D
The quick answer is no.
The SharePoint integration for 2012 will always show the latest version of the file.  And the DWF downloaded will always match the shown version of the file.
It sounds like you want a "released biased" view option for SharePoint.  For example, version 2 of a file is Released and version 3 is WIP.  Version 3 is the latest.
You would like a setting that causes SharePoint to display version 2 of the file?
I'll put this on the wishlist.
Doug Redmond
Software Engineer
Autodesk, Inc.
Thank you!
