Detect dark mode
Detect dark mode
FRFR1426
Detect dark mode
FRFR1426
Is there a way with the API to detect that the UI is in dark mode?
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
FRFR1426
I can read /Categories/Category/Property/CurrentSkin/Value (1: Dark, 2:Light) in %AppData%\Autodesk\Autodesk Vault Professional 2023\ApplicationPreferences.xml. But I'll only be able to switch the colors on the next restart.
Maxence DELANNOY
Manager
http://wiip.fr
Markus.Koechl
You can read the current theme on startup and establish an event handler to react whenever the user changed it.
void IExplorerExtension.OnStartup(IApplication application)
    mApplication = application;
    mCurrentTheme = VDF.Forms.Library.CurrentTheme.ToString();
    VDF.Forms.Library.ThemeChanged += ThemeChanged;
        private void ThemeChanged(object? sender, Library.UITheme e)
            mCurrentTheme = VDF.Forms.Library.CurrentTheme.ToString().ToLower();
 Extend the ThemChanged with your needs, like updating icons, etc..
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
FRFR1426
Note that this property (CurrentTheme) and this event (ThemeChanged) have been added in the 2024 version of the API. I'm on 2023...
Maxence DELANNOY
Manager
http://wiip.fr
