Is there a timeout on open Vault connections (when an application crashes)
Majjek
Majjek
When creating a new Vault connection via the API using the ConnectionManager, I understood it's best to always close/logout the connection when you're done or closing your application.
During development, sometimes the application crashes, which probably leaves a connection open.
What are the consequences of these leftover connections and are they automatically closed/cleaned up after a certain timeout?
Markus.Koechl
Unused connections time out. Developing with your Autodesk account on a single computer does not pull multiple licenses, so connections left open won't cause any issues before the timeout, either.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Majjek
Thanks for your response and the confirmation on the timeout Markus. I thought that maybe too many leftover open connections could influence server performance in someway.
