Data Standard Check-In Dialogue After Initial Save
-CraigZ-
-CraigZ-
Is there a way to disable the check-in dialogue that pops up immediately after the initial save of a new file when using Data Standard? When Data Standard is unloaded, this dialogue doesn't pop up.
I want to avoid filling the Vault with stuff that we don't end up using. Quite often we'll change a design before it's even been checked in for the first time and those parts just end up being clutter in Vault.
I know we can just hit cancel when it pops up, but I want to avoid that step entirely as I'm sure people will end up defaulting to just allowing it to check in and then we've got a bunk of junk in the vault.
Currently running Inventor Pro 2019 (no service packs) and Vault Workgroup 2019 (no service packs).
Xun.Zhang
Hello @-CraigZ-,
What is Data Standard here? Could you clarify a little bit?
Thanks!
Xun
-CraigZ-
Vault Data Standard. I wasn't sure whether it would be better to ask in Inventor or Vault forum because it's a Vault Add-In run on Inventor.
Xun.Zhang
Hmm...
This is a valid request, however, it should be disable the auto-notifiation somehow, let me check with Vault expert and update later.
Thanks!
Xun
-CraigZ-
Thanks. I've found the Vault Options inside the Vault tab in Inventor, but it doesn't seem to have what I'm looking for.
I've attached 2 screenshots of the options inside the Dialogue Suppression buttons and the Manage Prompts. I've also attached a screencast of what I'm trying to avoid (the check-in box at the end of the video).
I just want to clarify as well that I don't want it to automatically check these things in, I want it to automatically say no to checking them in (or disable the prompt entirely).
wangdu
You could switch off the check-in dialog after initial save by setting ShowCheckInDialog to false
<ShowCheckInDialog>True</ShowCheckInDialog>
in the Invetor.cfg file which can be found at the following location.
(e.g for VDS 2019  C:\ProgramData\Autodesk\Vault 2019\Extensions\DataStandard\CAD\Configuration.)
Hope it helps!
Wangdu
coolOrange
www.coolOrange.com
-CraigZ-
That is exactly what I'm looking for. Thank you!!
