Check-in files into vault using apprentice server
Jef_E
Jef_E
I am currently working on a Tool that allows NON-Inventor users to view property data and edit some properties. This portion works.
The second hurdle I am encountering is Checking the files back into Vault. I was assuming the user can use Vault but I was mistaken (see images for workflow).
My application uses Inventor Apprentice. Can I use the API to check-in the files in the VAULT? Or are there other methods that allow me to check-in files into vault? Please note that the users don't have Inventor installed only Inventor View.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
marcin_otręba
You Can do it, without problem, but you need to uncheck Disable check in of design files:
Znalezione obrazy dla zapytania vault settings Disable check in of design files
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
