How to programatically Update Properties from Vault (VaultPropertyWriteBack)
I'm using:
_app.CommandManager.ControlDefinitions["VaultPropertyWriteBack"].Execute();
This opens up a dialog box. I want to do the Update Properties after checking out a file without the popup. Is there a method in the SDK that duplicates this functionality?
Markus.Koechl
You are calling a user interface command that does not have an option to suppress the dialog. However, you could enforce updating properties on check out and set the option "Yes to all" & "Never Prompt". VaultInventorOptionsUpdatePropsYesToAllNeverPrompt.png
The Vault SDK does not have a corresponding function for this specific task of the Inventor Add-In. For a full programmatically executed approach, you could re-use the existing connection of the Inventor-Vault session, query the file's property from Vault and write the values to the file that you are handling.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
dg2405
Do you have a sample for updating the file properties programmatically via vault api?
I know Inventor API very good but Vault... 🤔
The only thing I've done was to get the current Revision via Ilogic from Inventor:
Dim mVltCon As VDF.Vault.Currency.Connections.Connection = VB.ConnectionManager.Instance.Connection
If mVltCon Is Nothing Then Exit Sub
Dim VaultPath As String = ThisDoc.PathAndFileName(True)
VaultPath = VaultPath.Replace("C:\Vault-Workspace\", "$/")
VaultPath = VaultPath.Replace("\", "/")
Dim VaultPaths() As String = New String() {VaultPath}
Dim wsFiels() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn,wsFiels(0))
Dim lifeCycleInfo As VDF.Vault.Currency.Entities.FileLifecycleInfo = mFileIt.LifecycleInfo
Dim fileRevInfo As VDF.Vault.Currency.Entities.FileRevisionInfo = mFileIt.RevisionInfo
Dim CurrentRev As String = fileRevInfo.RevisionLabel
Markus.Koechl
The code below updates multiple properties of a file:
//synchronize source file properties to export file properties for UDPs assigned to both
            try
                mTrace.WriteLine("Job tries synchronizing export file's properties in Vault.");
                //get the design rep category's user properties
                ACET.IExplorerUtil mExplUtil = Autodesk.Connectivity.Explorer.ExtensibilityTools.ExplorerLoader.LoadExplorerUtil(
                            connection.Server, connection.Vault, connection.UserID, connection.Ticket);
                Dictionary<ACW.PropDef, object> mPropDictonary = new Dictionary<ACW.PropDef, object>();
                //get property definitions filtered to UDPs
                VDF.Vault.Currency.Properties.PropertyDefinitionDictionary mPropDefs = connection.PropertyManager.GetPropertyDefinitions(
                    VDF.Vault.Currency.Entities.EntityClassIds.Files, null, VDF.Vault.Currency.Properties.PropertyDefinitionFilter.IncludeUserDefined);
                //get property definitions assigned to Design Representation category
                ACW.CatCfg catCfg1 = mWsMgr.CategoryService.GetCategoryConfigurationById(mExpFile.Cat.CatId, new string[] { "UserDefinedProperty" });
                List<long> mFilePropDefs = new List<long>();
                foreach (ACW.Bhv bhv in catCfg1.BhvCfgArray.First().BhvArray)
                    mFilePropDefs.Add(bhv.Id);
                //get properties assigned to source file and add definition/value pair to dictionary
                ACW.PropInst[] mSourcePropInst = mWsMgr.PropertyService.GetProperties("FILE", new long[] { mFile.Id }, mFilePropDefs.ToArray());
                ACW.PropDef[] propDefs = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE");
                foreach (ACW.PropInst item in mSourcePropInst)
                    VDF.Vault.Currency.Properties.PropertyDefinition mPropDef = connection.PropertyManager.GetPropertyDefinitionById(item.PropDefId);
                    ACW.PropDef propDef = propDefs.SingleOrDefault(n => n.Id == item.PropDefId);
                    mPropDictonary.Add(propDef, item.Val);
                //update export file using the property dictionary; note this the IExplorerUtil method bumps file iteration and requires no check out
                mExplUtil.UpdateFileProperties(mExpFile, mPropDictonary);
To get the full context of all references used, you may download the full example from here: https://github.com/koechlm/Vault-Sample---STEPExportJob
Markus Koechl
dinesh_nimbalkar
Observer
Observer
Hello Markus,
Could you please check github repo link? For me its not working..saying page not found.
Thank you.
Markus.Koechl
Hi @dinesh_nimbalkar : I am sorry for the wrong link. Here is the working one: Vault-Sample---InventorExportAnySampleJob/Autodesk.VLTINVSRV.ExportSampleJob/JobExtension.cs at 2025...
Markus Koechl
