Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
To select all/many and assign BOM location
It is time consuming to assign BOM location to individual item separately, specially when an item has more than 20 configurations.
5 Comments
HicksD.
I am in full agreement with Anakala!
The whole idea of this application is to make it easier for us to upload, track, and store data.
I consider the method required to set this data up for our purposes to be laborious.
I know that it could be easier with a few small changes.
Just changing this one aspect can shave days off the set up process!
This is not just a feature request - This effects the productivity of the user.
For example:
If a part model is to be uploaded/registered into Upchain, it roughly takes 5 clicks including search time (15 Seconds) to assign BOM location.
If the same part has 20 configurations(Solidworks), it roughly takes 20 x 5 = 100 clicks (5 Minutes) to assign BOM location.
This is just an example for one part. Since we have large assemblies & also hundreds of assemblies, the work which can be done in 1 month will need more than 8 months.
If this feature is provided to select all/many and assign BOM location then the time required will be reduced significantly.
abhinava_js
Community Visitor
I agree with Anakala
Even I have started uploading data to Upchain and I am facing the same issue.
@anakala_ramakanth
Thank you for posting your idea. This is under review by our product team.
Best regards,
Mladen
