Show only
Search instead for
In an IR using the Supplier RFQ - when adding an item there is nothing that lets you know that there is no supplier on the item added to the IR. It would be nice if there was a warning letting you know that the supplier list on the Item is empty
thank you for your idea request. While the IR workflow does not yet support supplier information check, maybe you could include a task within an IR workflow that would instruct the user to check the supplier information for sumbmitted item at the very start of the IR workflow?
Let us know if this would be helpfult to your use case and maybe give us more information about the nature of items submited in this kind of IR (e.g.development or released).
