Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Improve COPY/CLONE of Multiple instances of an item in an assembly
the issue.
  • If you select an item that has multiple instances in the BOM, all instances are selected.
  • Deselecting one item does not deselect all instances. This is incorrect as all items should be deselected.
  • If one or more items remain selected, all instances are cloned. This is incorrect and confuses the user.
Desired behaviour.
  • deselecting an item that is referenced more than once in an assembly would deselect all its references. this would eliminate the possibility of errors.
  • give the user a warning that deselecting the element will not clone anything. with advice to use copy and replace.
