Create a conversion rules tabel that the Admin could configure per Tenant for the GPS Conversion.
the Rules should enable the Admin to set the following rules.
- Item Type.
- File type.
- Attribute Values in Categories of the item.
- Item Status.
this rule would regulate what parts are converted to another Format.
example " if an Assembly is released per Workflow then only the released Item Parts with specific Attribute Values and not assemblies or subassemblies are converted to STEP"
this would reduce the load on the GPS and reduce the errors caused by large assemblies that sometimes cause the conversion to fail.
