Show only
Search instead for
It would be nice that the tenant administrator could create his own custom picklist for an item attribute. it would be simplier than having to ask the support assistance.
At present in the Upchain Web app, tenant administrators are able to modify 6 different picklist (such as Item.Finish, Item.HeatTreat, Item.Material and 3 others).
In the event where you are able to create a custom picklist, how would you want the system to behave in the following situations?
Remove an item attribute in the picklist that was used by an item in the system
Remove the entire picklist where some items has used one of its entry
Edit an item attribute in the picklist that was used by an item in the system
Edit the entire picklist where some items has used one of its entry
Regards, Paul Principal User Experience Designer (Upchain)
The engineering team has made it a priority to carry out feasibility studies and is currently investing time in this process. Unfortunately, I can't provide a projected timeline for completion at this moment.
