Idea.
Tenant admins should be able to add Custom attributes to Projects.
the logic should follow the same behaviour as Item attributes or Document attributes.
the Custom attributes must be.
- Editable by the tenant Admins.
- Searchable
- have different Data Typs.
- can be Project type specific or general for all projects.
- the connection to Project type must except multiple values.
- can be used in workflows as control primitives.
- are exposed to the API.
- values can be controlled by a Picklist.
Use Case.
better handling of different Projects. more search criteria leading to better results.
better control of Projects through Workflow primitives
