Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Cloud: PM Cannot edit the required by dates in a CN during the Approval Process
Expected behavior:
  • Date required field is editable by "Project manager" or "Lead Mechanical Designer"
Actual behavior:
  • Cannot edit date required field unless workflow is in draft
Workaround
  • Currently in cloud, the CN will allow editing only while the workflow is in a draft state. As a workaround, you can change the workflow back to a draft state when the required dates need to be changed.
(view in My Videos)
1 Comment
Thank you for submitting this idea!
This idea has been moved into future consideration and we have all the required info. We will keep you informed if the status changes.
Best regards,
Andreja Schneider
