How can I replace the latest version of an item with a previous version in my current working ebom?
venkateshBRNFX
venkateshBRNFX
Hello everyone,
In the picture below, I have marked the version number of the part(UPT 7). What should I do if I want to use the older version of the file in the same assembly?
In other words, the current version of the part is V4, what should I do if I want to replace the V4(of UPT 7) with the previous version V1 or V2 in the same parent assembly?
sven.dickmans
When you select the second tab 'Doc' in the integration panel, you will be able to re-download the file by using the green button in bottom right corner. The given download dialog then will let you choose the version to download and use.
Please note that you will have to close and reopen the file in your CAD session. In case of inventor, you can suppress and unsuppress the component to do so.
