When you select the second tab 'Doc' in the integration panel, you will be able to re-download the file by using the green button in bottom right corner. The given download dialog then will let you choose the version to download and use.
![Screenshot 2022-08-11 at 09.25.39.png Screenshot 2022-08-11 at 09.25.39.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1102735i3337B64EB4774C34/image-size/large?v=v2&px=999)
Please note that you will have to close and reopen the file in your CAD session. In case of inventor, you can suppress and unsuppress the component to do so.
